Draw a line perpendicular to the spline
anycganycgJ8A6A
anycganycgJ8A6A
Hi
I wish you a happy Christmas
I'm going to ask some difficult questions today.
The attached image shows the CAD screen
On the screen, the same distance to the spline
I want to draw a vertical line
Instead of using the space tool, the script will make the spline the same distance
I want to draw a line perpendicular to the vertex after division
is this possible ?
istan
also merry x-mas..either you or I drank too much punch.. I have no clue, what you talk about.. in the image there are > 9 polylines -  which vertex you talk about? Also you wrote about a vertical line or a perpendicular line..
anycganycgJ8A6A
##- thank you for answer
There is curve spline . I would like to make vertical line per divided
spline vertext can you understand ?-##
leeminardi
Here's a script that draws a spline defined as y = x^2 and then draws lines perpendicular to it.
I based it on the routine found here and just took a cross product of the tangent line with the z axis to get the perpendicular lines.  It can be modified to use an existing spline and to create a spline based on the end points of the perpendicular lines.  I assumed the spline lies on the XY plane. Getting a perpendicular line for a true 3D spline is a bit tricker as the are an infinite number to choose from!
	local sp = splineShape()
	addnewSpline sp
	for i = 1 to 100 by 10 do
		addknot sp 1 #smooth #curve [i, (i*i / 100.0), 0]
	updateShape sp
	sp.wirecolor = color 255 0 0
	local count = numknots sp - 1
	for i = 1 to count do
		local pathp = true
		local pt = interpBezier3D sp 1 i 0.50 pathParam:pathp
		local tn = tangentBezier3D sp 1 i 0.50 pathParam:pathp
		local perp = cross tn [0,0,1]
		local sperp = splineShape()
		addnewSpline sperp
		addknot sperp 1 #corner #line pt
		addknot sperp 1 #corner #line (pt + (perp * 20))
		updateShape sperp
		sperp.wirecolor =yellow
lee.minardi
