Dos commands freeze UI - even when using .NET Shell
Morne3D
Morne3D
Hi all
I have 3 Dos commands
Then I have a loop that runs X amount of times, based on the amount of contend in an array
In the loop I have another 14 Dos commands, with a progress bar updating between EACH dos command.
The Loop ends and I have another 3 Dos commands.
Doscommand freezes the UI untill the script is done. Any progress bars dont update during the freeze
HiddenDosCommand does the same thing. However if I use the switch
HiddenDosCommand ("bla bla bla") donotwait:true
..then the commands run nice and fast and the UI doesnt't freeze, BUT I CAN NOT do this, since each Dos command is dependant on the previous Dos command to complete, before it can continue, otherwise I get errors.
For example I can't create a folder with one command...
then copy files into it
then rename it
then copy more files
then delete the folder
...if the "create folder" part wasn't complete. This is a simplification in my explanation, as the actual commands are complex and take between 1 and 4 seconds to complete each
For the same reason ShellLaunch can't work, because each previous command should complete beforew the next one starts.
So I thought the answer was .NET
I have a function:
fn HiddenDotNetCommand Command=
	Process = DotNetObject "System.Diagnostics.Process"
	Process.StartInfo.FileName = "cmd.exe"
	Process.StartInfo.Arguments = "/C " + Command
	Process.StartInfo.UseShellExecute = false
	Process.StartInfo.CreateNoWindow = true
	Process.Start()
	Process.WaitForExit()
	--Process.StartInfo.UseShellExecute = false
	--Process.StartInfo.RedirectStandardOutput = false
	--string output = Process.StandardOutput.ReadToEnd()
The commented out bits is other things I tried
Then I call the Dos command with something like:
HiddenDotNetCommand ("bla bla bla")
Everything works beautifully if the array only has 1 object and the loop runs just once. If however there are 3 or 4 or more objects in the array, and then the loop runs 3 or 4 or more times, I AGAIN get the stuck UI until the script completes. It works fine, except the UI freezes.
Thoughts?
Morne3D
"windows.processPostedMessages()" did the trick
Also my progress bar needed float values instead of integer
