Direct access the material properties via pymxs
Carlo3000
Message 1 of 8
Carlo3000
Screenshot 2022-05-23 140535.jpgHi, I'm completely lost on this seemingly simple task.
I need to access the existing Octane's mix_material_001 and change the amount_value from 0 to 1 in Pymxs.
I know how to create the box, create the material and assigned it.
from pymxs import runtime as rt
t = rt.box()
m = rt.Mix_material()
t.material=m
m.amount_value = rt.float(1)
But how to directly access the already created "mix_material_001" without creating one?
m = rt.getClassInstances("mix_material_001") is not working.
Is there some lean code to directly access the scene material?
Replies (7)
Message 2 of 8
denisT.MaxDoctor
Message 3 of 8
Carlo3000
still searching for the solution
Message 4 of 8
Carlo3000
sorry, but I searched this help page before and I didn't find the solution on how to get specific material properties directly by material name. Is there a solution to access the material by its name without loops?
like the function to get the object by its name :
rt.getNodeByName('object_name')
the similar function, but for the material.
Message 6 of 8
denisT.MaxDoctor
@Swordslayer wrote:
updateSceneMaterialLib()
Message 7 of 8
Carlo3000
it works and it's so simpler than going for loops for every scene material. 🙂
thank you!
Message 8 of 8
Carlo3000
thank you!
