Detecting faces that are in exactly the same position as other faces (optimizing voxel geometry)
mikeZ7BJ8
Message 1 of 9
mikeZ7BJ8
I posted about this here and it was suggested I ask here, in the programming forum.
I'm looking for a way to optimize voxel geometry. The result (as shown in the attached screenshot) is a series of cubes that are all touching. I want to delete ALL the "inside" faces, that are touching other cube faces. I hope that makes sense.
Then I should be able to weld all the remaining verts to form the "shell", which I can then optimize. If anyone has any suggestions, it would be appreciated! I'm pretty new to 3ds Max, and am not a programmer. Thanks!
-Mike
Replies (8)
Message 2 of 9
Swordslayer
Thought I could use the OverlappingFaces xView interface that's already in max but it provided wrong results so here's a simple snippet that uses coords of the center of a face as a key for a dictionary and selects those that have more than one face sharing the same key (bottleneck is the address generation so if you want to improve performance, better use something else than the naive string concatenation):
	local voxelSize = 0.24
	local obj = $voxel_building
	local round = (dotNetClass "System.Math").Round
	fn posToRoundedStr pos = int (round pos.x) as string + ":" + int (round pos.y) as string + ":" + int (round pos.z) as string
	local halfSize = voxelSize * .5
	local facesByAddr = Dictionary #string
	local faceSel = #{}
	for face = 1 to polyop.getNumFaces obj do
		local addr = posToRoundedStr (polyop.getFaceCenter obj face / halfSize)
		if hasDictValue facesByAddr addr then append facesByAddr[addr] face
		else putDictValue facesByAddr addr #{face}
	for item in facesByAddr where item.value.numberSet > 1 do join faceSel item.value
	polyop.setFaceSelection obj faceSel
Message 3 of 9
denisT.MaxDoctor
deleted
Message 4 of 9
mikeZ7BJ8
It worked! I went to accept your solution, denisT.MaxDoctor, and now it says it's been deleted!
I ran your script and then used the Optimize modifier and got a 48k poly model down to 6.7k.
Message 5 of 9
denisT.MaxDoctor
Oh!
I didn't want to steal the better solution from Swordslayer.
here is the UI'ed Swordslayer's solution:
try(destroydialog rol) catch ()
rollout rol "RO:16AB3B8B" width:191
 	checkbox delete_ch "Delete Poly Dups" offset:[0,4]
	checkbox weld_ch "Weld Open Edges"
	button optimize_bt "Optimize" width:172 offset:[0,8]
	label info_lb "" enabled:off
	local _builtin = python.import #__builtin__
	local _round = _builtin.round
	fn round_pos pos ndigits:2 = [_round pos.x ndigits, _round pos.y ndigits, _round pos.z ndigits]
	on optimize_bt pressed do undo "Optimize" on
		if iskindof (node = selection[1]) editable_poly do
			local threshold = sqrt (polyop.getFaceArea node 1) / 2
			n0 = node.numfaces
			info_lb.text = [0, n0] as string
			local dict = Dictionary #string
			count = polyop.getnumfaces node
			dups = #{}
			for k=1 to count do
				c = polyop.getfacecenter node k
				hash = (round_pos c) as string
				if (i = dict[hash]) != undefined then
					append dups k
					append dups i
					--removedictvalue dict hash  -- ??? maybe not
				else dict[hash] = k
			free dict
			node.selectedfaces = dups
			if delete_ch.state do
				polyop.deletefaces node #selection
			if weld_ch.state do
				node.weldThreshold = threshold
				polyop.weldEdgesByThreshold node (polyop.getOpenEdges node)
			n1 = node.numfaces
			info_lb.text = [dups.numberset, n0] as string
	on rol open do
		info_lb.text = "select poly object"
createdialog rol
Message 6 of 9
denisT.MaxDoctor
welding should be improved. It seems that a multi-stage welding is needed - first by material ID ...
Message 7 of 9
denisT.MaxDoctor
You could probably ditch a couple hundred more triangles, easy.
Message 8 of 9
denisT.MaxDoctor
this is my best I could get with automatic optimization (keeping original material IDs)
Message 9 of 9
mikeZ7BJ8
Oh nice! Is this using swordslayer's code, that you adjusted here?
