Detach script with c ++
anycganycgJ8A6A
Message 1 of 45
anycganycgJ8A6A
hi
Nice to meet you
I have a problem
I have a 5000 object
That is attached..
I would like to detach with elements
I tested many detahel script
But all is failed or max freezz problem
So i found this link
C++ detach script
https://forums.cgsociety.org/t/c-detach-by-elements/1707338
If i use c++ , can i detach my objects
I dont know c++
Uf that is possible , can you help that ?
Replies (44)
Message 41 of 45
miauuuu
My numbers for the last code from Denis:
DETACH ... count:48600 time:94675 heap:437134480L
CREATE ... count:48600 time:941472 heap:56581836L
3ds Max 2020.
https://miauu-maxscript.com/
Message 42 of 45
denisT.MaxDoctor
Ha ha ha!!! My main machine is faster than my laptop...
I came back from a trip and tested on my main machine:
MXS:
DETACH ... count:48600 time:43255 heap:291744452L
CREATE ... count:48600 time:7035 heap:19624604L
C++(SDK)
count:48600 time:3526 heap:312L
Yes. Time in milliseconds 😊
Message 43 of 45
anycganycgJ8A6A
Can I ask you one question? If you detach while maintaining the map, will the speed increase tremendously?
Message 44 of 45
denisT.MaxDoctor
I'm pretty sure the speed should be the same or very close to the same.
Message 45 of 45
anycganycgJ8A6A
Wow good~
thank you
