Detach Faces to separate objects...
blakestone
blakestone
I understand that the MacroRecorder will only provide limited information of what 3dsMax is actually doing however in this example it does provide some useful information when detaching an objects face when done by hand... However when I try to replicate this via MaxScript it does not give the same result, it does detach the faces but does not detach them as a new object.
Does anyone know what the additional step/parameter I need to do this?
local my_selection = selection
local my_faces = my_selection.faces
for faces in my_faces do (
my_selection.setSelection #Face #{faces.index}
my_selection.detachToElement #Face keepOriginal:off
redrawViews()
Steve_Curley
DetachToElement doesn't detach the selection to a new object, only to an element of the current object (as far as I can see anyway). Equivalent to using the Detach button and ticking the "To Element" checkbox.
Try the PolyOp methods instead.
local polyList = #{}
polyList = polyOp.getFaceSelection selection
polyOp.detachFaces selection polyList delete:true asNode:true
That will detach all the selected polys to a single new object. If you want each discontinuous element detached separately then it will be a bit more involved, likewise if you want an object per poly.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
blakestone
Thanks Steve I figured it out... This script will detach each face as their own separate object:
local my_faces = undefined
local my_total = undefined
local my_faceSelection = undefined
local my_prefix = "newFace_"
-- Function: detach all faces in selected object
-- if multiple objects are selected only the first object in the array will be executed
function detachAllFaces = (
-- convert selected object to Editable Poly if it not already is
if (classOf my_selection != Editable_Poly) then (convertToPoly my_selection)
my_total = my_faces.count
-- detach all faces
for A1 = my_total to 1 by -1 do (
polyOp.setFaceSelection my_selection #{A1}
my_faceSelection = polyOp.getFaceSelection my_selection
polyOp.detachFaces selection my_faceSelection delete:true asNode:true name:(my_prefix + (A1 as string))
-- delete original object (which no longer has any attached faces)
delete my_selection
detachAllFaces()
barigazy
--detach faces, add name on the last created object, put pivot at the center of object (single face in this case)
fn detachOneByOne obj my_prefix: cntPivot: =
local poDetach = polyOp.detachFaces
for face = obj.faces.count to 1 by -1 do poDetach obj #{face} delete:true asNode:true name:(my_prefix+face as string)
if cntPivot do centerPivot objects
fn detachAllFaces affectFirstObj:on = if selection.count != 0 do
local objArr = for o in selection where isKindOf o geometryClass and not isKindOf o TargetObject collect (if not isKindOf o Editable_Poly do convertToPoly o ; o)
if objArr.count == 0 then messageBox "Select Geometry Objects Only!" title:"Warning" beep:off else
if affectFirstObj then
detachOneByOne objArr my_prefix:"newFace_" cntPivot:on
delete objArr
else
for o in objArr do (detachOneByOne o my_prefix:(o.name+"_newFace_") cntPivot:on)
delete objArr
clearSelection() ; free objArr
--if you want to detach all faces from first object in selection then run:
detachAllFaces()
--or if you want to affect all selected objects then use next line
detachAllFaces affectFirstObj:off
detachAllFaces()
Also you can try this script http://www.scriptspot.com/3ds-max/scripts/select-objects-by-bitmaptex
raoul_emilian
And how to use that script from scriptspot? Where i press to detach all faces to elements ? For me it doesnt work
denisT.MaxDoctor
There is usually no point in continuing a topic that is more than three years old, especially if you didn't start it.
Open a new one where you clearly explain your needs or problems.
raoul_emilian
Uuuu
