Delete SME views script causing error
TB_RIO
Message 1 of 23
TB_RIO
I have used this script for a while in conjunction with the 'show materials for selected' in order to quickly get materials in and out of the Slate Editor. Recently (I think it corresponds with me updating to Vray 5) the clear SME views one causes the below error, and a lot of the time causes max to crash.
I'm a complete scripting luddite and don't know what this means unfortunately, can anyone help!?
Or is there a more sensible way of doing it now (I'm on 2020)
here's the script:
-- Version:		v1.0
-- Author:			Aleksey Sheremetov  - https://kotiger.co/
macroScript Delete_SME_Views
category:"Kotscript"
tooltip:"Delete SME views"
buttontext:"DeleteViews"
	ViewsTotal = sme.GetNumViews ()
	ViewIndex = 1
	for i in 1 to ViewsTotal do
		view = sme.GetView (ViewIndex)
		if matchPattern view.name pattern:"*View*" then
			sme.DeleteView (sme.GetViewIndex (view)) false
		else
			ViewIndex += 1
Replies (22)
Message 21 of 23
calberto.cart
Ok I did another test with everything cleaned, delete a missing plugin and now It works beautifully, without freezes nor crashing, Ill keep up testing, thank u so much!!!
Message 22 of 23
denisT.MaxDoctor
Of course, it's great that you can now delete all views if you clear the scene beforehand. But the purpose of deleting all views is to clean up the scene. So it is desirable to do the whole cleaning in one automatic process.
In vain, you don't post a simple example file that can be used to reproduce failures. Knowing such "problem materials" or "scene conditions" will be useful to others.
Message 23 of 23
denisT.MaxDoctor
Here is the right way to delete all sme views:
	if sme.GetMainframe() == undefined do sme.Open()
	while sme.GetNumViews() do sme.DeleteView 1 false
This is how to delete only "View*" named views.
	for k = sme.GetNumViews() to 1 by -1
		where matchpattern (sme.GetView k).name pattern:"View*" do sme.DeleteView k false
