Announcements
Custom callback .Net
elpie89
elpie89
Hello all,
I'm trying to make communication between two plugin .NET
I managed to raise a callback from the first plugin and register the second plugin to that callback
GlobalInterface.Instance.BroadcastNotification(SystemNotificationCode.PreExport, filePaths);
in the second plugin, I grab the callback with
IGlobal global = Autodesk.Max.GlobalInterface.Instance;
IInterface18 ip = global.COREInterface18;
if (!callbackRegistered)
     this.fileSaveHandler = new GlobalDelegates.Delegate5(this.Global_PreFileSave);
     GlobalInterface.Instance.RegisterNotification(this.fileSaveHandler, null,SystemNotificationCode.PreExport);
     callbackRegistered = true;
Now the problem is that I need to retrieve an object between these two plugins
In this case an array of string is passed to GlobalInterface.Instance.BroadcastNotification
public void Global_PreFileSave(IntPtr obj, INotifyInfo _param1)
            object listFiles = _param1.CallParam;
string[] files = ((IEnumerable)listFiles).Cast<object>().Select(x => x.ToString()).ToArray(); // here I'm stacked }
 Any idea on how to retrieve this object?
elpie89
I actually found a way.
IUTF8Str file = Autodesk.Max.GlobalInterface.Instance.UTF8Str.Create(filePath);
Loader.Global.BroadcastNotification(SystemNotificationCode.PreExport, file);
I found that I cannot pass simple C# type,  like string int etc.
So the parameter must be a native 3dsmax type.
Let me say that is not coding, this is guessing stuff.
Of course, I found this on the wonderful documentation of 3DS max Smiley Mad
