Create XML exporter?
jeffmorris
Message 1 of 9
jeffmorris
Is it possible to create an XML exporter so that the Trainz Mesh Importer can import *.XML files and export *.IM files?
http://online.ts2009.com/mediaWiki/index.php/Trainz_Mesh_Importer
Replies (8)
Message 2 of 9
jeffmorris
There is a tutorial at http://help.autodesk.com/view/3DSMAX/2016/ENU//?guid=__files_GUID_537409FE_EF5B_4E02_8261_456F74134C... showing me how to create an exporter using MAXScript.
If I want to write a string to a file, I get two results:
print "trainzImport" to:out_file
result: "trainzInput"
out_text = "trainzInput"
format "%\n" out_text to:out_file
result: trainzInput
How do I use:
and have the file show:
trainzInput
and not:
"trainzInput"
Message 3 of 9
jeffmorris
Will someone PLEASE help me write XML exporter for Trainz?
Message 4 of 9
paulneale
Have you ever seen my dotNet help page for Max?
http://www.penproductions.ca/tutorials/dotNet/dotNet.htm
and more specifically
http://www.penproductions.ca/tutorials/dotNet/xml/xml.htm
Does that get you what you are looking for?
Paul Neale
http://paulneale.com
Paul Neale
Message 5 of 9
jeffmorris
How do I install and set up 3DS MAX 2016 SDK for Visual Studio 2013 or 2015?
Paul, I think that something is wrong with the forum on your PEN Productions website.
Message 6 of 9
paulneale
The forums don't work but those links should. They are just pages on my site. Follow tutorials link on the left if they don't for some reason.
You don't need Visual Studio installed as it is a Max Script solution.
Paul Neale
Paul Neale
Message 7 of 9
jeffmorris
I started writing the XML exporter. How do I remove the square brackets from the verticles? I want this line:
format "%%%\n" "<position>" (getVert tmesh v) "</position>" to:out_file
to output the following line:
<position>-7.5,-7.5,15</position>
and not
<position>[-7.5,-7.5,15]</position>
The Trainz Mesh Importer expects a triangle mesh with three verticles.
macroScript TrainzExport category: "HowTo"
fn GetGeometry o = (
 Superclassof o == Geometryclass and classof o != TargetObject )
obj = pickobject filter:GetGeometry
if isValidNode obj then
 tmesh =snapshotAsMesh obj
 out_name = GetSaveFileName()
 if out_name != undefined then
  out_file = createfile out_name
  format "%\n" "<trainzImport>" to:out_file
  format "%\n" "<version>1</version>" to:out_file
  format "%\n" "<mesh>" to:out_file
  format "%\n" "<triangles>" to:out_file
  num_verts = tmesh.numverts
  num_faces = tmesh.numfaces
  for v = 1 to num_verts do
  format "%\n" "<triangle>" to:out_file
  format "%\n" "<vertex>" to:out_file
  format "%\n" "</vertex>" to:out_file
  format "%\n" "</triangle>" to:out_file
  format "%\n" "</triangles>" to:out_file
  format "%\n" "</mesh>" to:out_file
  format "%\n" "</trainzImport>" to:out_file
  close out_file
  edit out_name
 )--end if
)--end if
)--end macroscript
<trainzImport>
   <mesh>
     <name>m.tiny</name>
     <triangles>
       <triangle>
         <materialId>0</materialId>
         <vertex>
           <position>0,0,2</position>
           <texcoord>0,0</texcoord>
         </vertex>
         <vertex>
           <position>10,0,2</position>
           <texcoord>1,0</texcoord>
         </vertex>
         <vertex>
           <position>10,10,2</position>
           <texcoord>1,1</texcoord>
         </vertex>
       </triangle>
     </triangles>
   </mesh>
   <materials>
     <material>
       <name>BrickWall</name>
       <id>0</id>
       <diffuse>1,1,1</diffuse>
        <textures>
         <texture>
           <textureName>c:/textures/brick.tga</textureName>
           <typeName>diffuse</typeName>
         </texture>
       </textures>
     </material>
   </materials>
 </trainzImport>
Message 8 of 9
paulneale
You have definitely done this the hard way. Dotnet/ MaxScript would be a far better solution and my example shows you exactly how to do this.
What you are looking for is position.x, position.y, position .z
Paul Neale
Paul Neale
Message 9 of 9
jeffmorris
tmesh = snapshotAsMesh selection[1]
out_name = ((GetDir #export)+"/testmesh.dat")
format "%,%\n" num_verts num_faces to:out_file
 vert = getVert tmesh v
 format "%" vert to:out_file
format "\n" to:out_file
for f = 1 to num_faces do
 face = getFace tmesh f
 format "%" face to:out_file
close out_file
delete tmesh
edit out_name
The code above came from 3DS Max 2016 online help at http://help.autodesk.com/view/3DSMAX/2016/ENU//?guid=__files_GUID_38562330_1435_4112_9265_DE965319A2... It creates a file below:
8,12
[-7.5,-7.5,0][7.5,-7.5,0][-7.5,7.5,0][7.5,7.5,0][-7.5,-7.5,15][7.5,-7.5,15][-7.5,7.5,15][7.5,7.5,15]
[1,3,4][4,2,1][5,6,8][8,7,5][1,2,6][6,5,1][2,4,8][8,6,2][4,3,7][7,8,4][3,1,5][5,7,3]
The first line shows the number of verticles and number of triangular faces.
The second line shows the coordinates of the verticles at each corner of the cube.
The third line shows the positions of the verticles for drawing each triangular face.
Position [1,3,4] have verticles at [-7.5,-7.5,0],[-7.5,7.5,0], and [7.5,7.5,0].
   <mesh>
     <name>m.tiny</name>
     <triangles>
       <triangle>
         <vertex>
           <position>-7.5,-7.5,0</position>
         </vertex>
         <vertex>
           <position>-7.5,7.5,0</position>
         </vertex>
         <vertex>
           <position>7.5,7.5,0</position>
         </vertex>
       </triangle>
     </triangles>
   </mesh>
How do I get each position and separate it into verticles?
1st face = 1,3,4
1st verticle = -7.5,-7.5,0
2nd verticle = -7.5,7.5,0
3rd verticle = 7.5,7.5,0
2nd face = 4,2,1
1st verticle = 7.5,7.5,0
2nd verticle = 7.5,-7.5,0
3rd verticle = -7.5,-7.5,0
3rd face = 5,6,8
1st verticle = -7.5,-7.5,15
2nd verticle = 7.5,-7.5,15
3rd verticle = 7.5,7.5,15
4th face = 8,7,5
1st verticle = 7.5,7.5,15
2nd verticle = -7.5,7.5,15
3rd verticle = -7.5,-7.5,15
so on?
