copy by reference or copy by vale
I was curious if it is known if maxscript will copy by reference or by value in default mode? For arrays I meant in assigning via the = operator.
Thx!
Swordslayer
Yes, it's documented and it's nothing out of ordinary. If you mean assigning to the variable, you have to explicitly pass it by reference, if you mean assigning the members, ie arr[i] = x, you'd have to explicitly copy (copy contents by reference)/deepCopy (copy contents by value) the array to avoid overwriting original contents.
