Coordinats of Multiple selected objects
kem.star
kem.star
Hey Guys,
for a Game with an editional Map editor i need the Coordinats and optionaly the Rotation of all the Selected Objects in 3dsmax.
The selectable count should be high as possible and the coordinats/rotation should be copyable (need them to insert in the other editor)
Should be look like this
If 10 Objects Selected and i Run the Script , it should give me in the listener something like
Coordinates
Object 1(1,1,1)
Object 2(2,2,2)
Object 3(3,3,3)
Object 4(4,4,4)
Object 10(10,10,10)
Rotation
Object 1(90,0,0)
Object 2(65,0,0)
Object 3(30,0,0)
Object 4(270,0,0)
Object 10(359,0,0)
JokerMartini23
The rotation will be a slight bit more work because it's most likely handled differently in your game versus 3ds Max. However here is a start. This snippet will do the coordinates. For the sake of you learning try to modify it to do rotation yourself.
clearlistener()
sel = getCurrentSelection()
print "Coordinates"
for i = 1 to sel.count do
	obj = sel[i]
	pos = obj.pos
	format "Object % (%,%,%)\n" i pos.x pos.y pos.z
kem.star
It worked perfectly thx dude.
If anyone need the rotation too.. heres the solution
clearlistener()
print "Coordinates"
	obj = sel[i]
	pos = obj.pos
print "Rotation"
	obj = sel[i]
	rotation = obj.rotation
	format "Object % (%,%,%)\n" i rotation.x rotation.y rotation.z
