Connecting two nodes in Slate Material Editor
paradisebuster44
Observer Observer
paradisebuster44
Observer
Observer
Hi
I am having a tough time figuring this one out. I have a script that creates a standard MultiTile Node and a CoronaPhysicalMtl node. I simply want to connect the output of the MultiTile node to the input Base Color of the CoronaPhysicalMtl.
Since the script is in python, I would prefer to find a solution within it.
Any suggestions would be appreciated.
Thanks!
from pymxs import runtime as rt
# Get the Slate Material Editor interface
sme = rt.sme
# Check if a Slate view is active
if sme.activeView == 0:
    print("Please open the Slate Material Editor to run this script.")
else:
    # Get the active Slate Material Editor view
    active_view = sme.GetView(sme.activeView)
    # --- Create a MultiTile texture map ---
    multi_tile_map = rt.MultiTile()
    multi_tile_map.name = "My_MultiTile_Map"
    # Create a node for the map in the active view at position (100, 100)
    map_node = active_view.CreateNode(multi_tile_map, rt.Point2(100, 100))
    # --- Create a Corona Physical Material ---
    corona_mat = rt.CoronaPhysicalMtl()
    corona_mat.name = "My_Corona_Material"
    # Create a node for the material, positioned to the right of the map
    material_node = active_view.CreateNode(corona_mat, rt.Point2(350, 100))
    print("Successfully created MultiTile and CoronaPhysicalMtl nodes in the Slate Material Editor.")
denisT.MaxDoctor
mat = rt.PhysicalMaterial()
mat.BaseColorMap = map
paradisebuster44
Observer
Observer
Thank you!
