Check parameter validity (C++)
chrisdawlud
chrisdawlud
I want to check whether a scene object has it's "texmap" parameter set or not. I couldn't find API for that so I came up with the following, but it doesn't work:
auto object = lightNode->GetObjectRef();
if (isVrayLight(object))
	auto pb = static_cast<IParamBlock2*>(GetReference(0));
	Texmap* texmap;
	auto success = pb->GetValueByName(TSTR{ "texmap" }, TimeValue{}, texmap, Interval{});
	// if (!Texmap) doesn't work properly either
	if (!success) {}
// I also tried this:
	auto texmap = pb->GetTexmap(34, TimeValue{}, Interval{});
	if (!texmap) {}
The second example involves hardcoding the ID (in this case, 34, which I deducted from within maxscript by running getpropnames $). Does anyone know a better way to get it or should I just stick to GetValueByName()?
denisT.MaxDoctor
If you want to check a specific property, you must specify a name and find it by name.
If you are looking for all the properties of TYPE_TEXMAP, you can go through all and find by property type.
When you say "it doesn't work", what does not work?
chrisdawlud
The problem was I forgot to call GetReference() specifically on 'object' rather than this->GetReference() so it works as expected now. I just wasn't sure if this approach is correct.
I also found out that I can obtain the ID like this:
auto texmap_id = object_pb->GetDesc()->IndextoID(
	object_pb->GetDesc()->NameToIndex(TSTR"texmap" }));
object_pb->ReleaseDesc();
