Change Lathe modifer direction/ alignment via Max Script
info82NDX
info82NDX
I am trying to change a Lathe modifier direction via Max script:
select $MySpline
modPanel.addModToSelection (Lathe ()) ui:on
$MySpline.modifiers[#Lathe].axis = 2
However I am getting this error
-- Error occurred in anonymous codeblock; filename: ; position: 444; line: 16
-- Unable to convert: 2 to type: Matrix
-- MAXScript callstack:
-- thread data: threadID:7852
-- [stack level: 0]
-- In top-level
Any help would be great
info82NDX
solved my own problem, I needed to use a matrix, here's the correct format for anyone looking:
$MySpline.modifiers[#Lathe].axis = matrix3 1
