Capturing object names using NodeEventCallback when nameChanged: and geometryChanged:
kenc
kenc
Hi all
I am writing a script using NodeEventCallback to save an object's nameChanged: and geometryChanged: to 2 arrays.
ObjChangedName and ObjChangedGeom
When the script is run, it does append to the arrays but as a ID or handle. What I need is the object name to populate a multilistbox rollout.
global Obj, ObjChangedName = #(), ObjChangedGeom = #()
try
callbackItem = undefined
gc light:true
catch
fn CallbackFunc1 NodeEvent1 Obj =
appendIfUnique ObjChangedName Obj
fn CallbackFunc2 NodeEvent2 Obj =
appendIfUnique ObjChangedGeom Obj
callbackItem = NodeEventCallback mouseUp:true delay:1000 nameChanged:CallbackFunc1 geometryChanged:CallbackFunc2 Obj
When run this the content of the 2 arrays are
ObjChangedName is #(#(50770), #(50813))
ObjChangedGeom is #(#(50813))
What I need is the object names.
I also noticed that the geometryChanged: event does respond to move/rotate/position changes
I guess this is a 2 part question post.
I'd appreciate any help please.
A娘
you didn't need put your script , put detail of the purpose
MartinBeh
Just guessing (no time to read the docs): Are those numbers the object "handles"?
Edit: They are not the normal handles but AnimHandles. The docs say:
"The callback functions always take two parameters: the first is the event name that triggered the function call, the second is a list of node AnimHandles"
So you would need to use
GetAnimByHandle <integer>
to retrieve the scene objects.
So one of your functions could look like this:
	for o in obj do (appendIfUnique ObjChangedName (GetAnimByHandle o))
Some more minor remarks
  • I don't think you need to declare Obj as global, and also there seems to be no need to add it as last argument to NodeEventCallback
  • Maybe you might want to look into the 'when' change handler instead of the NodeEventCallback, it also allows to catch both geometry and name changes and might be easier to work with
Martin B   EESignature
→ please 'Like' posts that are helpful; if a post answers your question please click the "Accept Solution" button.
sc95VR4MA
I normally use something like this:
yourObject = getNodeByName (The Object Name Reference Here)
Select yourObject
--Then do whatever to the object.
kenc
@A娘
I'm not sure where this script is going to be used yet. My boss asked that I try to detect when objects are modified.
kenc
@MartinBeh
This does work, thank you.
But, I was just given the word to stop development on this, unfortunately.
Since your code snippet did work for me, I will mark your post Accept Solution.
Thank you again.
