can not access aec wall with maxscript
hainamcad
hainamcad
i can not create wall with maxscript, can not change wall width and height with maxscript , can not use " pick spline " function with maxscript ? can you help me ?
thank and best regard from vietnam
denisT.MaxDoctor
Are you sure you are talking about AEO Wall, not AEO Railing?
hainamcad
thank for your reply , i said AEC WALL , example :
a = wall ()
show a
maxscript listenner :
$Wall:Wall002 @ [0.000000,0.000000,0.000000]
.Generate_Mapping_Coords : integer
.Justification : integer
.height : float
.width : float
.realWorldMapSize : boolean
false
but i can not use a.height = 1000 ? is it a 3dsmax bug ?
denisT.MaxDoctor
well... that's bad. bad for you ...
The Wall Object is not a friend of the MXS tools developer. Perhaps you can set and change all UI settings using the Windows API, but I think it's not worth it.
Just find any better built-in solution. At least that's what I would do.
Swordslayer
The UI doesn't expose any, they're just creation time parameters (and setting them works as such so next time you create the wall through UI, the height will use the value). While it might be possible to startObjectCreation and simulate mouseclicks, I don't think that's worth it, better use spline with Extrude and Shell w/ Straighten Corners checked, for example.
hainamcad
thank you
Swordslayer
That's a good point. Though technically not a bug but a rather unfortunate design, you can try both filing a bug report and suggesting that as a new feature (see the links in my signature).
