Can I make messagebox not show?
Message 1 of 11
I wanna to build a program that will load model files and export to other format file automatically.
But the message box make my program pause.
Could I override something so that I can handle it in code.
Replies (10)
Message 2 of 11
hainamcad
use print function instead messagebox
Message 3 of 11
denisT.MaxDoctor
what exporter do you use? some exporters follow #noPrompt flag of the exportFile method
anyway, you can always close any popup dialog using the DialogMonitorOPS interface and its mechanics
(see the MXS help for more details)
Message 4 of 11
This messagebox shows when I load a model with vray material.
I don't use any exporter, I build it myself.
I've built a obj exporter with c#, it won't show the messagebox.
And I also need to export .vrscene (I have no idea now).
The messagebox still shows even though I call this method and set noprompts = true. It seems not working.
MaxPlus.FileManager.Open(string name, bool NoPrompts)
I will read information for DialogMonitorOPS interface and its mechanics.
Thanks.
Message 5 of 11
I have no idea how to control it.
Message 6 of 11
MaxPlus-specific implementation for general silencing of dialogs is
MaxPlus.Application.SetQuietMode (True)
Silencing in MaxScript can be done via
setQuietMode True
and
setVRaySilentMode()
MaxScript can be executed using MaxPlus.Core.EvalMAXScript
Message 7 of 11
I tried. But it seems not working.
The messagebox about vray still shows.
Anyway, thanks.
Message 8 of 11
What message is that exactly?
Can you post a screenshot of the message?
Message 9 of 11
this one. I do not want it show.
Message 10 of 11
Since it's a V-Ray message then it should be controlled by setVRaySilentMode()
but I can't test that since I cannot reproduce the dialog.
I'm pretty sure that this dialog never gets shown when 3dsmaxbatch.exe is used for processing.
I process thousands of V-Ray scenes that way and never get a single dialog.
You can also check out Chaos Group Forums
Message 11 of 11
really thanks. I'll try it
