Camera modifier in 3ds Max 2024
bodyulcg
bodyulcg
Faced one problem. I wrote a scripted modifier that worked in all the latest versions of 3ds Max including 2023. But in 3ds Max 2024 (including update 1) on the physical camera, the program freezes when starting the render. Also, the modifier cannot be added to the cameras of third-party render engines, such as VRay or FStormRender, due to the fact that it is not in the list of modifiers.
The code is something like this:
plugin modifier CameraMod
classid:#(0x673ca7f0, 0x46ef9c4b)
    parameters main rollout:params
        amount type:#float ui:spnAmount
    rollout params "Parameters"
        spinner spnAmount "Amount: "
It turned out that if the built-in modifier can be added to third-party cameras, then it works fine on the physical and does not cause a freeze.
The first thing that came to mind was to inherit from the modifier class that can be added to FStormCamera. The full list is here. I used CamPerspCorrect. But when adding "extends:CamPerspCorrect" or any other class, 3ds Max crashes when opening old scenes that contain a non-inherited modifier.
Here's what I did, but I'm not sure if it's the right solution:
  • Renamed current class to CameraMod_Legacy and added "invisible:true".
  • Made a new class, with the old name but a new classid, inherited from CamPerspCorrect.
  • Made a conversion from legacy to a new modifier using #filePostOpen callback, but as an alternative it can be done in the legacy version in the load / postload event.
Whole code:
plugin modifier CameraMod_Legacy
invisible:true
classid:#(0x673ca7f1, 0x46ef9c4b)
replaceUI:true
fn checkForLegacyCameraModInstances =
    local legacyInstances = getClassInstances CameraMod_Legacy
    for legacy in legacyInstances do
        local new = CameraMod()
        for p in getPropNames legacy where isProperty new p do
            setProperty new p (getProperty legacy p)
        replaceInstances legacy new
callbacks.addScript #filePostOpen "checkForLegacyCameraModInstances()"
Question:
Did I do everything right? Maybe instead of CamPerspCorrect, it's better to use another one, for example, EmptyModifier_Old (Attribute Holder (Old))?
JasonLuckett
Why hasn't this been addressed Autodesk, this is over 6 months old and from a great little developer?
After finally updating to 2024 after the cursory 3 month wait for bugs to be ironed out, I hit this problem today and have discovered this problem.
This little script is very useful, it should be incorpoarted into your never updated physical camera.
Does anyone from Autodesk ever read these boards?
Thanks @bodyyulcg for chasing this.
Jason
istan
I'd create a ticket and post it to: https://beta.autodesk.com
giuseppe.schiralli
We will look into this. I'll forward the code to our devs.
Can you please confirm that if the viewport is not set to the Physical camera (for example Perspective), a rendering using Arnold RenderView set to the Phys camera works fine?
If I read correctly, there are 3 problems:
- rendering freezes when the custom modifier is applied to a Phys camera, regression from Max 2023
- the modifier cannot be applied to a 3rd party camera, unless it extends an existing modifier
- compatibility issue with old scenes with a non-inherited modifier.
Thank you for the report.
-Giuseppe
Giuseppe Schiralli
3ds Max - QA Analyst>
denisT.MaxDoctor
Based on the description above, I understand that this is not a camera modifier per se, but rather a modifier used as a container for custom parameters. In that case, it would be more correct to use a custom attribute added to the base camera object. This approach would avoid problems with any camera, including third-party cameras.
