c++ pass max objects as argument
MehdiZangenehBar
MehdiZangenehBar
I want to pass array of objects as argument and work on it's items, but I got some exception and weird errors. This is my code:
#include <maxscript/maxscript.h>
#include <maxscript/macros/define_instantiation_functions.h>
def_visible_primitive(TestFunction, "TestFunction");
Value* TestFunction_cf(Value **arg_list, int count)
   Array* nodesArray = (Array*)arg_list[0];
   INodeTab* nodes = new INodeTab();
   for (int i = 0; i < nodesArray->size; i++)
      INode* node = (INode*)nodesArray->data[i];
      nodes->AppendNode(node);
   mprintf((*nodes)[0]->GetName());
   return &ok;
Where is my mistake?
istan
why you cast this?
did you check e.g.:
  type_check( arg_list[0], MAXNode, "not a node" );
  MAXNode * Mnode = (MAXNode*) arg_list[0];
MehdiZangenehBar
Because I want to pass array of nodes, not a single node.
MehdiZangenehBar
And this the edited and finalized version:
#include <maxscript/maxwrapper/mxsobjects.h>
INode* MaxNodeToINode(Value* value)
	INode* node = NULL;
	if (is_node(value))
		MAXNode* maxNode = (MAXNode*)value;
		if (!deletion_check_test(maxNode)) node = maxNode->to_node();
	return node;
void MaxArrayToINodeTab(Value* value, INodeTab& nodes)
	if (value->is_kind_of(class_tag(Array)))
		Array* maxArray = (Array*)value;
		for (int i = 0; i < maxArray->size; ++i)
			INode* node = MaxNodeToINode(maxArray->data[i]);
			if (node)nodes.AppendNode(node);
	// TestFunction <nodes>
	INodeTab nodeTab;
	MaxArrayToINodeTab(arg_list[0], nodeTab);
	if (nodeTab.Count() == 0)return &false_value;
	mprintf(L"%s\n", nodeTab[0]->GetName());
	return &true_value;
