C++ getFaceMtlIndex API is given incorrect material index for instanced Objects
12:54 PM
I have created the scene with following the steps,
- Created a Sphere
- Created Multi/Sub-Object Material using Material Editor
- Assigned 3 standard materials with bitmap for above Multi/Sub-Object Material
- Assigned Multi/Sub-Object Material to the Sphere
- Separated the Sphere for UVW clusters using Flatten Mapping method
- Unwrap UVW Modifier > Edit UVs rollout > Open UV Editor button > Edit UVWs dialog > Polygon sub-object level > Mapping menu > Flatten Mapping
- Animated Sphere using Material Modifier with applying 3 standard materials IDs
- Material IDs are 1, 2 and 3
- Cloned a Sphere object using instance option
Instanced object is taken incorrect material ID for relevant time which was added in the Material Modifier animation.
Could anyone please check it and advise me to get correct material IDs for above user scenario?
I have attached the sample scene with above issue occurred.
