Bezier_Rotation and Smooth Rotation in MAXScript?
Message 1 of 1
This topic has two seperate yet related questions:
- In MAXScript, there is a Bezier_Rotation class. However, there is no controller associated with that class listed in the Assign Rotation Controller dialog box. How would I make use of this class?
- I set an object's rotation controller to Smooth Rotation, select it, and execute this line:
print selection[1].rotation.track
 It prints "Controller: Smooth_Rotation". However, there is no Smooth_Rotation class in MAXScript. Then I execute this:
print selection[1].rotation.track.keyable
 It prints "true". How would I access the keys in this controller? I found no documentation for any "Smooth_Rotation" class.
My goal is to export position/rotation key information to my own file format for use in a DirectX engine. The engine will interpolate the values in between these every frame to animate objects. Therefore, the controllers I use must be keyable. I am using Bezier_Position for translation, and I would like to use something similar (if not the same) for rotation.
Tyler
Replies (0)
