Batch Import .stp files into 3ds max 2020
Roger.Bastow
Message 1 of 11
Roger.Bastow
Hi, this is my first post and I really hope someone could help. 😃
I need to Batch import about 2000 .stp files into 3DS max 2020. Is there a script that would cover this, or could someone support in writing one?
Kind regards
Roger
Replies (10)
Message 2 of 11
miauuuu
I don't have .step files to test the code. IF the extensions of your file is .stp you have to modify the code(replace .step with .stp).
The script allows you to select folder where step files are located. You can't select step files separately.
	function GetFilesRecursive root pattern =
		dir_array = GetDirectories (root+"\*")
		for d in dir_array do
			join dir_array (GetDirectories (d+"*"))
		my_files = #()
		for f in dir_array do
			join my_files (getFiles (f + pattern))
		my_files
	dir = getSavePath caption:"Select the directory" initialDir:"$scenes"
	if dir != undefined do
		filesArr = #()
		filesArr = getFiles (dir+"\*" + ".step")
		subFiles = GetFilesRecursive dir ("*" + ".step")
		if subFiles.count != 0 then
			msg = "The selected folder has subfolders!\n"
			msg += "Do you want to include the files from the subfolders too?"
			if queryBox  msg title:"Sub-folders found" do
				join filesArr subFiles
		if filesArr.count != 0 do
			for f in filesArr do
				importFile f #noPrompt
https://miauu-maxscript.com/
Message 3 of 11
jetboy_hrn1990
Community Visitor
Community Visitor
 Thank you.
I change to  extension to STL. This Script Work STL files. STP cant include.
Message 4 of 11
miauuuu
Just tested on max2020 with some STP files downloaded from the internet and the script does work:
		my_files = #()
		my_files
		filesArr = #()
		filesArr = getFiles (dir+"\*" + ".stp")
		subFiles = GetFilesRecursive dir ("*" + ".stp")
Message 5 of 11
denisT.MaxDoctor
getfiles "c:/temp/*" recurse:on
getfiles has an option #recurse. You don't need a custom method for recursion.
Message 6 of 11
miauuuu
I know. 🙂
This was a copy-paste from a very old code.
Message 7 of 11
denisT.MaxDoctor
@miauuuu wrote:
I know. 🙂
be modern ☝️😎
Message 8 of 11
miauuuu
OK. 🙂
		files02Arr = getFiles (dir+"\*" + ".stp") recurse:on
		if files02Arr.count > filesArr.count do
			if queryBox  msg title:"Sub-folders found" do filesArr = files02Arr
			for f in filesArr do importFile f #noPrompt
Message 9 of 11
denisT.MaxDoctor
	recurse = on
		path = pathconfig.appendpath dir "*.stp"
		filesArr = getFiles path recurse:recurse
		for file in filesArr do importFile file #noPrompt
initialdir
doesfileexist -- I was wrong!
if filearr.count != 0
Message 10 of 11
miauuuu
What if we want to tell the user that there are subfolders with .stp files and to ask if those files has to be included?
Message 11 of 11
denisT.MaxDoctor
To the question of how to select files for batch processing - recursively or not. In general, it doesn't matter, but batch processing in any case implies preliminary preparation, and in practice, it makes no sense to give options during the process, but it is enough to set conditions in advance.
