attachObjects fails to attach objects
32loyal
32loyal
Iam trying to take two nodes and put node2 into node1 but when i run the script it gives me a error saying Unable to convert:#($LOD222) to type:<node>.It seems that the node variables arent actually of type node,i dont know what i need to call to get the correct variable types.any help is appreciated
node1 =  getNodeByName "LOD222" exact:true ignoreCase:false all:true
node2 =  getNodeByName "_e94c_Var1_LOD3" exact:true ignoreCase:false all:true
attachObjects node1 node2 move:true
istan
why don't you check in the mxs-listener what the contents of node1 and node2 are?
32loyal
Sorry I didn't mention IAM still new to max script how exactly would I do this?
miauuuu
Try this:
node1 = selection[1]
node2 = selection[2]
node2.parent = node1
node2.pos = node1.pos
https://miauu-maxscript.com/
ads_royje
Hi @32loyal ,
in the message error : Unable to convert:#($LOD222) to type:<node>
is because #($LOD222) is an array of 1 node, not a node.
The getnodebyname will return an array of nodes instead of a node when the all:true argument is passed.
Either use node1[1] and node2[1] to get the first node of the array of node or remove the all:true argument.
32loyal
Ok perfect this all makes sense now, that its returning a array instead of a single node your solution and @miauuuu would work the only difference is i would need a "max select" command for miauuuu solution.I've opted to set the all parameter in getNodyByName to false to only get a single node.Thanks for everyones help and input i appreciate it
miauuuu
You can use my code without selecting any objcets. Its just need a little modification:
	node1 =  getNodeByName "LOD222" exact:true ignoreCase:false all:false
	node2 =  getNodeByName "_e94c_Var1_LOD3" exact:true ignoreCase:false all:false
