append numbers to name
joegunn3d
joegunn3d
Thought I'd post this since it seems I can't find an example of what I'm trying to do.
Basically, if I have a bunch of objects that are already named correctly. I just want to append a unique number to them.
thanks
max2008-11
Steve_Curley
Give us an actual example of what the names are now and what you want them to be. It matters (different coding) if you want "1" on the end or "01" like Max usually does itself.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
joegunn3d
Lets say my objects are name liked this:
BoxOpen01
SLight12
RingMapWhat_0012_X01
Now after I select all my objects I would like something like this:
BoxOpen01_01
SLight12_02
RingMapWhat_0012_X01_03
max2008-11
Steve_Curley
That's going to be tricky, unless you were to encode the original names in the script.
If you just select them then there's no guarantee that they will be in the right order, so you might end up with
SLight12_01
RingMapWhat_0012_X01_02
BoxOpen01_03
If having them in alphabetical order would be sufficient:-
BoxOpen01_01
SLight12_03
then it could be done by sorting the selection before making any changes.
If the order is irrelevent then it's easier.
This example does sort them first. Select the objects before running it.
ar = for obj in selection collect obj.name
sort ar
for t = 1 to ar.count do
newName = stringstream ""
n = getNodeByName ar
format "%_%" ar (formattedprint t format:"2.2d") to:newName
n.name = newName as string
Max 2016 (SP1/EXT1)
joegunn3d
Thanks a lot Steve your great! I ended up using some crappy code in the mean time which works. I don't mind the order in which they get numbered just as long as they get numbered.
for i in selection do
i.name = i.name + (random 1 100) as string
I'm going to take a look at what you posted and replace my crazy code...
Thanks again!
max2008-11
Steve_Curley
In that case:-
for t = 1 to selection.count do
format "%_%" selection.name (formattedprint t format:"2.2d") to:newName
selection.name = newName as string
Problem with "somenumber as string" is that you won't get the leading zero which leads to inconsistently named objects. Apart from that there's nothing really "crappy" with your code ;)
Max 2016 (SP1/EXT1)
joegunn3d
Thanks for the reply. That looks like clean code for what I need. I appreciate it.
Thanks again!
max2008-11
