Alphanumeric sorting in maxscript
Currently using this function by Swordslayer to sort my collection of children in a parent:
fn CompareNames str1 str2 = stricmp str1.name str2.name
Problem is, it doesn't handle alphanumeric names. A lot of the children have a numeric prefix. When treated as a string, like in the function above, 10-name is sorted before 4-name. Trying to get my sorted children to match the order in Max (sorted ascending).
Any suggestions on how to sort alphanumerically?
Thank you in advance for your help.
Swordslayer
Too lazy to write the function myself:
fn getSHLWAPI =
	source =  "using System;\n"
	source += "using System.Runtime.InteropServices;\n"
	source += "class SHLWAPI\n"
	source += "{\n"
	source += "	[DllImport(\"shlwapi.dll\", CharSet = CharSet.Auto)]\n"
	source += "	public static extern int StrCmpLogicalW(string lpszStr, string lpszComp);\n"
	source += "}\n"
	csharpProvider = dotnetobject "Microsoft.CSharp.CSharpCodeProvider"
	compilerParams = dotnetobject "System.CodeDom.Compiler.CompilerParameters"
	compilerParams.GenerateInMemory = on
	compilerResults = csharpProvider.CompileAssemblyFromSource compilerParams #(source)
	compilerResults.CompiledAssembly.CreateInstance "SHLWAPI"
if ::SHLWAPI == undefined do SHLWAPI = getSHLWAPI()
x = #("name10", "name4", "name20", "name100")
qsort x SHLWAPI.StrCmpLogicalW --> #("name4", "name10", "name20", "name100")
Thank you so much for the solution Swordslayer.
Currently using some more of your suggested code to get all the children of a group/parent:
childObjects = for obj in stepParent.children where (classOf obj != XRefObject) collect obj
Problem is, I cannot get the alphanumeric sorting function to work on it. I also tried:
childObjects = parent.children
How can I put the children into an array/collection that qSort will work on?
I want to sort the objects and not just the names so that I can manipulate the objects once sorted.
Thank you again for your help.
Swordslayer
It works on any array, not on collections. Use SHLWAPI.StrCmpLogicalW in place of stricmp in the compareNames function, i.e.
fn compareNames str1 str2 = SHLWAPI.StrCmpLogicalW str1.name str2.name
Thank you again. That did it for me.
