Align object's pivot to object's orientation
kenc
Message 1 of 61
kenc
I have a DXF from Softplan that I import into max. When the objects come in they all have the same pivot rotation orientation. I then center the pivots to each object's center as seen in image1.jpg
What I need to do is by maxscript is to align the object's pivot to the object's orientation. In image2.jpg the pivot for an object does not align with the object but rather at 45 degrees.
In image3.jpg this is how I need to rotate the pivot to align with the object.
Help would be much appreciated.
TIA
Accepted solutions (3)
Replies (60)
Message 21 of 61
kenc
@leeminardi that script didn't work. X and Y are not in the x y plane.
Here's a max file.
I imported using the dialog shown in the JPG
I delete everything except the 2 PANEL and 2 SURFACE meshes. So now all I have is the PANEL and SURFACE meshes. I froze the SURFACE meshes and only there so you can see what the orientation of the PANELS should be.
I attach PANEL0 to PANEL.
I weld the vertices then detach by element so all the doors are separate.
You can see that the pivots for all the doors are pointing in the same direction.
Some of the doors have their pivots perpendicular to the door and the rest are not. The ones not perpendicular are the ones that need the pivots rotated so they are perpendicular.
Message 22 of 61
leeminardi
@kenc the file appears to have all the panel doors as one object.  I thought they were going to be separate objects.
Checking, as you did, "Create one scene object..." sould make them separate objects.
@istan if the geometry and pivots are weirdly skewed in 3D usig matrices could work but I think quats are the safer, and maybe easier, route in that they avoid the potential for gimbal lock.
lee.minardi
Message 23 of 61
kenc
@leeminardi oh gees I attached the wrong file. Try this one
Message 24 of 61
denisT.MaxDoctor
In this particular case, the solution may be:
fn setPivotRotation obj tm =
	worldAlignPivot obj
	local rot = inverse tm.rotationpart
	animate off in coordsys local obj.rotation *= rot
	obj.objectoffsetrot *= rot
	obj.objectoffsetpos *= rot
	obj.objecttransform
mapped fn alignPivotToFace obj face:#max zUp:on = if iskindof obj Editable_Mesh do
	fn getMaxFace obj =
		fmax = meshop.getfacearea obj 1
		i = 1
		for k = 2 to obj.numfaces where (area = meshop.getfacearea obj k) > fmax do
			fmax = area
			i = k
		i
	fn matrixZUp tm =
		side = normalize (cross z_axis tm[3])
		front = cross side z_axis
		matrix3 front side z_axis tm.pos
	if face == #max do face = getMaxFace obj
	norm = getfacenormal obj face
	tm = matrixfromnormal norm
	if zUp do
		tm = matrixZUp tm
	centerPivot obj
alignPivotToFace geometry
Message 25 of 61
kenc
@denisT.MaxDoctor thank you. I'll give it a try.
Message 26 of 61
kenc
@denisT.MaxDoctor Almost. Is it possible to adjust the script so the y-axis is perpendicular to the doors?
Message 27 of 61
denisT.MaxDoctor
matrix3 side front z_axis tm.pos
and you probably have to change the sign of “side” or “front” to make the right order
Message 28 of 61
kenc
@denisT.MaxDoctor -front, -side and -front/-side don't work. I am going to go through your code and try to wrap my head around.
Message 29 of 61
denisT.MaxDoctor
	worldAlignPivot obj
	obj.objecttransform
	fn getMaxFace obj =
		i = 1
			fmax = area
			i = k
		i
	fn matrixZUp tm =
		front = cross z_axis side
	if zUp do
		tm = matrixZUp tm
	centerPivot obj
Message 30 of 61
istan
quod erat demonstrandum: Look at code from Denis..
Message 31 of 61
denisT.MaxDoctor
Since we are looking for a Z-Up matrix, a good improvement to the above solution might be to search only all faces orthogonal to the Z-axis.
Message 32 of 61
domo.spaji
Than author would came with something like:
c=cylinder sides:4
I meant to ask him is that aligned to object orientation.
Also, I meant to ask him why does he need this.
I kind of doubt he have "real" reason, even wrong one...
But I rarely get answers here...
Wonder why 😄
Message 33 of 61
denisT.MaxDoctor
Wonder why 😄
Perhaps your questions are philosophical in nature.
Who needs all the windows facing north?
Message 34 of 61
domo.spaji
Also, I meant to ask author of near by post how did he  managed to get "a big" working script from "AI".
I'm not surprised  at A"I" knowledge in script language, but the other one...
Not working exactly as commented but. i believe that part is human work 😁
Message 35 of 61
domo.spaji
Didnt get it was really question...
And no way I would try to think about it or answer it!
I really doubt I would get it if somebody asked me out of all this orientation context...
Even checked in translator if north is still "north"😂
I'm laughing from the moment it hit me
Message 36 of 61
kenc
@domo.spaji
The cabinet doors will be swappable in unreal. Y-axis is front and pivot is at center back. There is a lot more to the MAX to UNREAL workflow we have and too much to explain.
Message 37 of 61
kenc
@denisT.MaxDoctor thank you. The door pivots are perpendicular to the door orientation now.
I went through your code and I can not understand what is happening exactly. I'll have to come back to it when I have time. Right now I'm being pressured to get this working.
How do I rotate the pivot about the z-axis say by 180 degrees?
Message 38 of 61
denisT.MaxDoctor
prerotatez tm 180
Message 39 of 61
denisT.MaxDoctor
tm = prerotatez tm 180
Message 40 of 61
kenc
@denisT.MaxDoctor more specifically. In the attached image, the z-axis of the pivot needs to be rotated by 180 so the y-axis is pointing out away from the cabinet SURFACE. What I do is shoot a ray 2 inches in both directions in the y-axis. If the ray strikes SURFACE then I know the pivot needs to be rotated 180 in the z-axis. I already have the code setup to detect if it needs to be rotated. I just need to rotate it now.
