Adding .mse script file as a toolbar button
Ive been trying to add a script i downloaded from scriptspot to my toolbar.
I can only run the said script ,I cant open it with maxscript inside the program.
Can someone tell me a way I can add this one and eventually futre scripts as toolbar button ?
This is the script Im trying to add :
http://www.scriptspot.com/3ds-max/scripts/quad-primitives
blakestone
mse files are encrypted files so you can not 'open' them only 'run' them.
a workaround would be to create a new maxscript which simply calls this mse file and assign that to your toolbar, something like this:
( fileIn "c:\myscript.mse" )
Swordslayer
If you want that automated for you, there's Macroscript Creator to simplify the task.
As a side note, you might use proper quadcylinder and quadsphere primitives: Quad Cylinder Primitive (quad sphere is in the comment section).
