A macroscript that references PBR materials wrote only works if I evaluate it myself
michael_grosberg
michael_grosberg
I wrote a macroscript that changes the UV channels on materials of selected objects. It only works on physical and PBR materials, and only bitmap textures. It's a pretty simple script. My problem is, when I start up 3ds max, this script doesn't work on objects with PBR materials. To get it to work if I have to open the script in the editor and press CTRL+E.
I pinpointed the problem to a single line. As far as I can tell, this conditional statement gets interpreted as false first, then as true after manual evaluation:
     if (classof CCmat == PBRMetalRough) then (...)
a similar condition for Physical materials works just fine "out of the box".
I have a test file plus the script attached.
Swordslayer
If I understand the purpose of the script right, you want to change map channel for all the BitmapTextures (and nothing else) used in materials of selected objects? If so, this might be easier:
macroScript ChangeChannels
category:"AAA"
tooltip:"ChangeChannels"
ButtonText:"ChangeChannels"
icon:#("MergeAnim",4)
	mapped fn changeBitmapChannels obj channel =
		for map in getClassInstances BitmapTexture target:obj do
			map.coords.mapChannel = channel
	rollout ChangeChannelsUI "Multitool" width:200 height:100
		button btnChangeChan "Change" width:60 height:24 across:2 tooltip:"change materials on selected objects to using a different map channel"
		spinner spnChangeChan "Channel:" width:80 height:20 type:#integer range:[1,99,2]
		on btnChangeChan pressed do
			changeBitmapChannels selection spnChangeChan.value
	on execute do if not ChangeChannelsUI.open do
		createDialog ChangeChannelsUI 200 100 900 300
