3dsmaxPluginWizard vs. VS2019
istan
Advisor Advisor
istan
When reading the documentation, it says to copy the wizard files to "VC\VCProjects", but there exists no "VCProjects" path under VS2019 ?!
istan
ok, i created the missing folder and it's showing now..
istan
and "Wizard=VsWizard.VsWizardEngine.16.0" has to be used for VS2019..
Hi @istan, I followed the same steps, but the plugin project appears as a "Visual Studio 2010" project. That was odd. Anyway, I decided to change the  version of the SDK and the tools to VS2019 (as it should be) in the project's properties, but I ended up with a MSB4019 error, though it's not a migrated project. Sad thing.
Any idea? Thanks! 🙂
istan
Any idea? Thanks! 🙂
You have to set "Platform Toolset" to V141
and I usually also check the SDK version and manually set it to 8.1 or 10.0.xx (in my case it doesn't matter, as I still use only low level winsdk stuff)
