3ds max multi format batch converter script
system-core
Message 1 of 1
system-core
All code used belongs to - Batch Convert MAX Files v1.0/miauu's Batch Save/Export tool
https://bodyulcg.com/product/batch-convert-max-files/
https://miauu-maxscript.com/portfolio-item/miauus-batch-save-obj-fbx-3ds-as-max-files/
I've been trying to modify miauu's batch converter to export multiple formats. I think I'm close maybe, I still get errors
How can I get rid of the xRefCnt I think it was only used for saving previous max file versions.
for i = 0 to xRefCnt where (lv_Batch.Items.Item[i].checked == true) do with redraw off
Also having issues with this export code this says no data
				importFile maxFiles[i+1] #noPrompt
				filePath = getFilenamePath maxFiles[i+1]
				fileName = (getFilenameFile maxFiles[i+1])
				newName = filePath + "\\" + fileName + file_type
					exportFile newName
				resetMaxFile #noPrompt
				pb_xRefprogress.value = 100.0 * i / xRefCnt
					windows.processPostedMessages()
Full code
	global rol_miauuBatchConvert
    try(destroyDialog rol_miauuBatchConvert)catch()
    rollout rol_miauuBatchConvert "miauu's BatchCovert" width:585 height:543
		local get_path
	    local get_files
	    local set_path
		local ConvertClass = dotnetclass "system.convert"
		local ImageClass = dotnetclass "system.drawing.image"
		local logoIcon = "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"
		local openFileRoll = dotNetObject "System.Windows.Forms.OpenFileDialog"
        local disableForeColor = (dotNetClass "System.Drawing.Color").white
        local maxFiles = #()
		local name_of_type = #(
		"3D_StudioExporterPlugin (.3DS)",
		"Adobe_Illustrator (.AI)",
		"DWG_Export (.DWG)",
		"DWF_Exporter (.DWF)",
		"STL_Export (.STL)",
		"FBXEXP (.FBX)",
		"ObjExp (.OBJ)"
    	dotNetControl 'lv_Batch' "system.windows.forms.listView" pos:[10,10] width:273 height:200 align:#left
    	dropdownList 'ddl1' "File type:" pos:[13,308] width:176 height:40 items:#("3D_StudioExporterPlugin (.3DS)", "Adobe_Illustrator (.AI)", "DWG_Export (.DWG)", "DWF_Exporter (.DWF)", "STL_Export (.STL)", "FBXEXP (.FBX)", "ObjExp (.OBJ)") align:#left
    	checkbox 'chk1' "Show settings window for each file" pos:[15,354] width:188 height:15 align:#left
    	button 'btn_getDir' "Get Directory" pos:[290,10] width:108 height:21 toolTip:"Select all .max files in the given folder and/or its sub-folders" align:#left
    	button 'btn_getFile' "Get file(s)" pos:[290,35] width:108 height:21 toolTip:"Select one or multiple files in given folder" align:#left
    	button 'btn_clear' "Clear" pos:[290,60] width:108 height:21 align:#left
    	checkbox 'chkBox_showFullPath' "Show Full Path" pos:[10,215] width:94 height:15 align:#left
    	label 'lbl_select' "Select:" pos:[120,215] width:32 height:13 align:#left
    	button 'btn_all' "All" pos:[157,214] width:40 height:18 align:#left
    	button 'btn_none' "None" pos:[200,214] width:40 height:18 align:#left
    	button 'btn_invert' "Invert" pos:[243,214] width:40 height:18 align:#left
    	button 'bnt_saveAsPrevious' "Convert" pos:[10,235] width:275 height:30 align:#left
    	progressBar 'pb_xRefprogress' "" pos:[10,270] width:275 height:14 value:0 color:(color 0 255 0) align:#left
		--	Credist to Peter Addington - http://lonerobot.net/?p=314
		function String2Bmp string =
			local clipboardClass = dotNetClass "System.Windows.Forms.Clipboard"
			local imageclass = dotNetclass "System.Drawing.image"
			local bytearr = convertclass.FromBase64String string
			local memstream = dotnetobject "System.IO.MemoryStream" bytearr
			local DecodedImg = ImageClass.fromstream memstream
			memstream.close()
			DecodedImg
		--	credits to Denis Trofimiv - http://forums.cgsociety.org/showpost.php?p=7708817&postcount=21
		function LoadMyLogoAsTitlebarIcon =
			d = (windows.getChildHWND 0 rol_miauuBatchConvert.title)[1]
			WM_SETICON = 0x0080
			ICON_SMALL = 0
			bm = dotnetobject "System.Drawing.Bitmap" (String2Bmp logoIcon)
			ptr = bm.GetHicon()
			icon = (dotnetclass "System.Drawing.Icon").FromHandle (dotnetobject "IntPtr" ptr)
			windows.SendMessage d WM_SETICON ICON_SMALL icon.handle
        function AddColumns theLv columnsAr=
            if chkBox_showFullPath.state == false then
                w=(theLv.width)-6
            else
                w=(theLv.width)+400
            for x in columnsAr do
                theLv.columns.add x w
        function PopulateListView theLv=
            rows=#()
            for x=1 to maxFiles.count do
                    mapName = (getFilenameFile maxFiles[x])
                else
                    mapName = maxFiles[x]
                li = dotNetObject "System.Windows.Forms.ListViewItem" mapName
                append rows li
            theLv.items.addRange rows
        function InitListView theLv=
            theLv.clear()
			theLv.headerStyle = theLv.headerStyle.none
            theLv.view = (dotNetClass "system.windows.forms.view").details
            theLv.FullRowSelect = true
            theLv.MultiSelect = true
            theLv.checkBoxes = true
            theLv.backcolor = (dotNetClass "System.Drawing.Color").DimGray
            theLv.forecolor = (dotNetClass "System.Drawing.Color").lightGray
        function BatchListViewReIinit =
            InitListView lv_Batch
            AddColumns lv_Batch #("")
            PopulateListView lv_Batch
        function TurnBatchLVchkBoxOn =
            for i = 0 to lv_Batch.Items.count-1 do
                lv_Batch.Items.Item[i].checked = true
            lv_Batch.forecolor = disableForeColor
        function OpenFolders folderToOpen =
            local checkFolderName = substring folderToOpen 1 (folderToOpen.count-1)
            if (symbolicPaths.isPathName checkFolderName) then
                folderToOpen = symbolicPaths.getPathValue checkFolderName
            shellLaunch "explorer.exe" folderToOpen
        function GetFilesRecursive root pattern =
            dir_array = GetDirectories (root+"\*")
            for d in dir_array do
                join dir_array (GetDirectories (d+"*"))
            my_files = #()
            for f in dir_array do
                join my_files (getFiles (f + pattern))
            my_files
    	on rol_miauuBatchConvert open do
    		try(LoadMyLogoAsTitlebarIcon())catch()
    		openFileRoll.title = "Select Files"
    		openFileRoll.Multiselect = true
    		openFileRoll.Filter = "max (*.max)|*.max"
    		openFileRoll.FilterIndex = 1
    		openFileRoll.RestoreDirectory = true
    	    AddColumns lv_Batch #("Files")
    	on lv_Batch mouseDown arg do
    	    --    delete selected max file from the listview
    	    if arg.button==arg.button.middle then
    	        if (hitNode = lv_Batch.GetItemAt arg.x arg.y) != undefined do
    	            deleteItem maxFiles (hitNode.index+1)
    	            BatchListViewReIinit()
    	    --    open folder of selected max file
    	    if arg.button==arg.button.right then
    	            f = (hitNode.index+1)
    	            folderToOpen = (getFilenamePath maxFiles[f])
    	on btn_getDir pressed do
    	    dir = getSavePath caption:"Select the directory" initialDir:"$scenes"
    	    if dir != undefined do
    	        maxFiles = #()
    	        --    get all max files
    	        maxFiles = getFiles (dir+"\*.max")
    	        --    check for subfolders
    	        subFiles = GetFilesRecursive dir "*.max"
    	        if subFiles.count != 0 then
    	            msg = "The selected folder have subfolders!\n"
    	            msg += "Do you want to include the files from the subfolders too?"
    	            if queryBox  msg title:"Sub-folders found" do
    	                join maxFiles subFiles
    			makeUniqueArray maxFiles
    	        TurnBatchLVchkBoxOn()
    	on btn_getFile pressed do
    		result = openFileRoll.showDialog()
    		result.ToString()
    		if (result.Equals result.OK) do
    			filePath = (openFileRoll.fileNames)
    			join maxFiles filePath
    	on btn_clear pressed do
    	    maxFiles = #()
    	on chkBox_showFullPath changed state do
    		cbState = for i = 0 to lv_Batch.Items.count-1 collect lv_Batch.Items.Item[i].checked
    	    for i = 0 to lv_Batch.Items.count-1 do lv_Batch.Items.Item[i].checked = cbState[i + 1]
    	on btn_all pressed do
    		for i = 0 to lv_Batch.Items.count-1 do lv_Batch.Items.Item[i].checked = true
    	on btn_none pressed do
    		for i = 0 to lv_Batch.Items.count-1 do lv_Batch.Items.Item[i].checked = false
    	on btn_invert pressed do
    		for i = 0 to lv_Batch.Items.count-1 do lv_Batch.Items.Item[i].checked = not lv_Batch.Items.Item[i].checked
    	on bnt_saveAsPrevious pressed do
		local file_type = case ddl1.selection of
			1:".3ds"
			2:".ai"
			3:".dwg"
			4:".dwf"
			5:".stl"
			6:".fbx"
			7:".obj"
			default:".3ds"
				if chk1.state then
					exportFile (set_path + "\\" + (GetFileNameFile i) + file_type)
				else
					exportFile (set_path + "\\" + (GetFileNameFile i) + file_type) #noPrompt
				saveMaxFile newName useNewFile:true quiet:true
				if curMaxVersion > 12 do
    		completeRedraw()
    		resumeEditing()
    		setArrowCursor()
    createdialog rol_miauuBatchConvert width:405
Replies (0)
