3ds max material editor
kterasawa
kterasawa
3ds max2017_material editor
ビットマップでマテリアルを取り込んだのですが、「マテリアルを選択に割り当て」ボタンがグレーアウトしていて機能しません。取り込んだ後に何か作業が必要なのでしょうか。
malcomarmstrong
Perhaps post in English if you are on an English speaking page. that way, we can assist you.
istan
我一點都不明白 😉
malcomarmstrong
如果您在英文页面上发布信息,您可以用英文写下您的问题。它可以更轻松地回复您的问题。谢谢。
kterasawa
After blowing material with Bitmap, "Assign Material to Selection" button is still grey-out,
do I need to do anything else?
malcomarmstrong
I think blowing may be the wrong word, but I will try to answer. When you have set up your material, is anything selected in the viewport? If not, select something and see if the button is available to press. If you do have something selected, in the material editor, use the go to parent button and makes sure you are at the top level of the material. Check if assign to selection button is now available. It may be that you are at a submap level and need the whole material to add it to selection.
我认为吹吹可能是错误的词,但我会尽力回答。当你设置你的材料时,在视口中选择了什么?如果没有,请选择一些内容并查看该按钮是否可用于按下。如果您确实选择了某些内容,请在素材编辑器中使用“转到父级”按钮并确保您位于材质的顶层。检查是否可以使用分配到选择按钮。这可能是因为您处于子图级别,需要将整个材质添加到选区中。
