3ds max crashes when I turn on render
kngbugaj
Observer Observer
kngbugaj
Observer
Observer
Hey,
I have a problem with 3ds max. When I turns on render, the program turns off. I see this information:
I don't know what can I do. I tried uninstalling corona and 3ds max.
Has anyone had a similar problem?
muratcanyeniarascom
1. Make sure you have the latest updates for 3ds Max installed. You can check for updates on Autodesk's official site.
2. Make sure your computer has enough RAM and free disk space. Rendering can use large amounts of memory.
3. Look at 3ds Max log files. These files are usually located in the “C:\Users[UserName]\Documents\3dsMax\autoback” folder. Log files can provide more information about which process is causing the error.
4. Check if the drivers on your computer are up to date. It is especially important that the graphics card drivers are up to date.
5. If the problem persists, you can Reset 3ds Max.
https://forums.autodesk.com/t5/3ds-max-maya-turkce/3ds-max-resetleme-ayarlari-sifirlama/td-p/7989769
Enjoy your work.
