3ds Max 2021 - Hybrid (debug) Build is not working
nnikbin
nnikbin
I've downloaded 3ds Max 2021 - Hybrid (debug) Build from my ADN panel. When I run 3dsmax.exe from the x64/hybrid folder, it only shows splash screen for less than a second, then closes. It only creates InstallSettings.ini which contains the following text:
[Least User Privilege]
useUserProfiles=0
I have the same problem in running 3ds Max 2020.3 - Hybrid (debug) Build and running Hybrid (debug) versions from my project solution.
Regular version of 3ds Max 2021 is installed on my machine and works without any problem. The contents of its InstallSettings.ini is:
useUserProfiles=1
installedBuild=1
Does anybody have any idea how to solve the issue?
attilaszabo
Hi @nnikbin ,
Thank you for reporting this issue and we are sorry you are experiencing it.
The 3ds Max 2021 ADN build that is currently available for ADN members to download has pre-release (beta) licensing, hence it won't work when you have the regular (non-beta) release of 3ds Max 2021 installed.
We are working to remediate this problem, and will follow up here as soon as we have a new ADN build tested on our end and posted for you to download.
Best regards,
Attila Szabo
Product Owner, Autodesk 3ds Max
Attila Szabo
Product Owner, 3ds Max
nnikbin
Hi @attilaszabo
Thank you for your reply.
kevinvandecar
Hi @nnikbin , As @attilaszabo mentioned his team was able to produce a new 3ds Max 2021 build that runs adjacent to the production version. This seems to be resolved now, and it's great to see your confirmation in this thread.
I have updated the ADN member site, so anyone needing it as ADN member can get it from there.
Therefore will mark this as solution.
thanks for the continued feedback!
kevin
Kevin Vandecar
Developer Technical Services
Autodesk Developer Network
navid.nikbin
Thank you @kevinvandecar and thanks again to @attilaszabo and his team.
