Here is an Autodesk "example" file. Run it and see that the module is not importable. Marvelous. How are you supposed to do anything when the supplied info lets you down at virtually every opportunity? Might help that they are consistent with the use of PySide2 as the message statement on line 54 is still PySide and not PySide2.
UI platform which demostrate the PySide2 ui loading and
display object tree on explorer.
-Feng Du
import os, sys
from PySide2 import QtCore, QtWidgets
import MaxPlus
import pymxs
sys.path.append(os.path.dirname(os.path.abspath(__file__)))
from maxDataModels import mxTreeNode
from qtViewModels import vmodelMaxObjects
rt = pymxs.runtime
uitype, basetype = MaxPlus.LoadUiType(os.path.join(os.path.dirname(__file__),'mainUI.ui'))
class PyMaxExplorer(basetype,uitype):
def __init__(self, parent=None):
super(PyMaxExplorer,self).__init__(parent)
self.setupUi(self)
self.buildViewModel()
self.connectActions()
self.setupMaxCallbacks()
def setupMaxCallbacks(self):
self._callbackItem = rt.NodeEventCallback(all=self.cbNodeEvent)
def teardownMaxCallbacks(self):
self._callbackItem = None
def buildViewModel(self):
self._rootNode = self.buildTree(rt.rootNode)
self._proxyModel = QtCore.QSortFilterProxyModel()
self._model = vmodelMaxObjects(self._rootNode)
self._proxyModel.setSourceModel(self._model)
self._proxyModel.setDynamicSortFilter(True)
self._proxyModel.setFilterCaseSensitivity(QtCore.Qt.CaseInsensitive)
self.treeView_objects.setModel(self._proxyModel)
self.treeView_objects.setSortingEnabled(True)
QtCore.QObject.connect(self.uiGraphFilter, QtCore.SIGNAL("textChanged(QString)"), self._proxyModel.setFilterRegExp)
def connectActions(self):
self.connect(self.actionWatch, QtCore.SIGNAL('triggered()'),self.actWatch)
self.connect(self.actionAbout, QtCore.SIGNAL('triggered()'),self.actAbout)
self.connect(self.actionRefresh, QtCore.SIGNAL('triggered()'),self.actRefresh)
self.connect(self.actionExit, QtCore.SIGNAL('triggered()'),self.actExit)
self.connect(self.actionUndo, QtCore.SIGNAL('triggered()'),self.actUndo)
self.connect(self.actionRedo, QtCore.SIGNAL('triggered()'),self.actRedo)
def actWatch(self):
self.Watcher.show()
def actAbout(self):
QtWidgets.QMessageBox.about(self, "PyMaxExplorer 1.0", "PyMaxExplorer is a demo for pymxs and PySide usage on 3ds Max")
def actRefresh(self):
def actExit(self):
self.close()
def actUndo(self):
pymxs.run_undo()
def actRedo(self):
pymxs.run_redo()
def cbNodeEvent(self, event, node):
def buildTree(self, mxObj, parent = None, userName = ''):
nodeName = mxObj.name
if userName:
nodeName = userName
newNode = mxTreeNode(nodeName, parent)
for c in mxObj.children:
self.buildTree(c, newNode)
return newNode
Gets you this:
Import Error: No module named maxDataModels
Seriously poor. Makes no mention of appending sys.path or any other way to ensure that (what I assume is a built in module) gets loaded.
