3ds Max 2018 Menu Problem - Cant click on sub menus
Message 1 of 29
Hello, so I have installed 3ds max 2018 from 2017, and there is a problem, I go onto any menu e.g. File, Edit, Tools etc. and I can click on them all and they all work, but when there is an arrow next to one so there are more buttons e.g. File > Export, I cannot click on any buttons that show, they disappear and I can't click them.
Replies (28)
Message 21 of 29
I had the same issue with a recent switch from 2017 to 2018. the two files fixed the problem.
Thank You
Message 22 of 29
666alekso
I had the same problem and that files fixed for me thx 🙂
Message 23 of 29
ihooper
By the way, this fix is also included with 2018 update 4, so the recommended action at this point is to apply the update rather than using the scripts posted here.
Ian Hooper
UX Architect
Message 24 of 29
GARYOSAVAN
Observer
Observer
That one solved my problem. Thanks. 🙂
Message 25 of 29
I have the same issue with 2018. After copying the files where advised, I still cannot use the import/export functions.
I pasted the .ms file in \stdscripts and the .py file in scripts\Python.
Can you help?
Thank you,
Luiza
Message 26 of 29
ihooper
Are you running 2018 Update 4? The fix is included in that build.
Ian Hooper
UX Architect
Message 27 of 29
yes........ your script has worked.........😍
Thank you
Message 28 of 29
Ran into this issue today.  The scripts still work.  Hard to believe that this still hasn't been permanently fixed for all machines.
Message 29 of 29
Hi, i try this, still not working
