3ds Max 2013 SDK Learning Path - Can't find code
Hey everyone,
I've just started learning 3ds Max 2013 SDK, using the docs and the online training videos on Autodesk. The problem is I can't find the source code for the 3ds Max 2013's learning path. I'm referring to this: http://docs.autodesk.com/3DSMAX/15/ENU/3ds-Max-SDK-Programmer-Guide/files/GUID-C59F7DCE-8B96-4A49-A4...
I checked out the dev repository over here as well: http://code.google.com/p/3ds-max-dev/
but all I could find was the samples for 2012 and 2014, nothing for 2013.
I apprecaite if anyone who has a clue, can let me know where I could find the code for 2013 learning path.
Thanks Smiley Wink
drew_avis
Hi dreamsurfer, unfortunately there's no Learning Path code for 2013.  However, the 2014 code should work as-is.
Drew
Drew Avis
Content Experience Designer
