Is there a Way to use the Pack Custom function in the UV Editor to decide in which UDIM do you want to pack the Elements (Fe: I have 2 Elements in U1V1 and I want one of them to be Packed Custom in U5V3, but if i select that Element it's just packed in the U1V1)
Solved by 10DSpace. Go to Solution.
@Anonymous
Unfortunately, the answer is No. Pack Custom packs everything or whatever you have selected into the U1V1 tile only. What I do when I am setting up UV tiles is to make separate material IDs for the polygons that I want to be in separate UV tiles. Then with the dropdown list in the UV Editor Window you can select 1 UV Tile set of polys at a time, Unwrap and pack them. When done with unwrapping and packing individual tiles they will all be in the U1V1 tile, but now you can select by material ID and move them via offset to the UV tiles you want. In case you are not aware, you can make material ID assignments via the UV Editor in the Material ID section of the rollout which is handy to not have to go back to Editable poly to do so.
Thank you for your assistance, that was a very helpful advice. I'm aware of the material ID's and I've found a great way to properly pack custom in the UV tile that you desire: When done dealing with the ID's, select the ID and in the Move modifier, instead of moving them with the cursor, change the value of the U and V coordinates down in the UV editor, this way once one ID is packed, if you move them +1U, +1V, they're placed in the U2V2.
@Anonymous
You are welcome. Yes, the "Offset" function in the UV Editor is the way to go for moving the UV islands into different UV tiles once you have them unwrapped and packed. I think your post made this clearer to those not familiar with it as I only briefly mentioned 'moving them via offset'. Thanks.
