3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Urgent Modeling
9 REPLIES 9
Message 1 of 10
1059 Views, 9 Replies
Urgent Modeling
Hello everyone
can anyone give an idea how can i model this in 3ds max
check attachment
Urgent Modeling
Hello everyone
check attachment
9 REPLIES 9
Message 2 of 10
Fadhil_Farook
Fadhil_Farook
Look into SPLINES if you want a faster method. You can make use of the SWEEP modifier to enhance your workflow.
https://www.youtube.com/watch?v=QdVt__Cibic
https://www.youtube.com/watch?v=YuaMllw_O6o
Message 3 of 10
miledrizk
miledrizk
I made this Sceencast to demonstrate one possible way of doing this kind of structures.
There are more than one method, and this is one of them.
I didn't try to get it 100% like the photo, but as close as possible.
Hope it will be helpful
miledrizk@gmail.com
3DS Max 2021, V-Ray 5.2
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
My YouTube Channel http//www.youtube.com/c/MiledRizk
miledrizk@gmail.com
Message 4 of 10
Fadhil_Farook
in reply to: miledrizk
Fadhil_Farook
Adding to @miledrizk's great screencast, for the sake of your object, convert your object into an EDITABLE MESH instead of an EDITABLE POLY so as to get the Diagonal segments as well. When you convert your edge selection to a shape, make sure to uncheck IGNORE HIDDEN EDGES. The rest is everything from the mile's screencast. See Attachment-1 for an illustration.
Message 5 of 10
Fadhil_Farook
Fadhil_Farook
Message 6 of 10
Fadhil_Farook
Fadhil_Farook
Message 7 of 10
Fadhil_Farook
My Apologies for the previous duplicates. My browser stopped responding and executed multiple instances as I clicked POST.
Message 8 of 10
miledrizk
miledrizk
@Fadhil_Farook Good point regarding the fact that, in case you need to create inner diagonals, it's better to have at the end an Editable Mesh modifier.
Quick Edit: If you want to collapse your model, first make a copy of your file, and do the collapsing in the copied file,
This way you can keep the original as a template that you can modify the different steps in the process and extract different variations
Of the structure.
miledrizk@gmail.com
Of the structure.
miledrizk@gmail.com
Message 9 of 10
Thank you som mush for this great video
Message 10 of 10
miledrizk
miledrizk
Welcome! 🙂
miledrizk@gmail.com
Welcome! 🙂
miledrizk@gmail.com
