3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
The model clearly has hard edges, but it still looks smooth. What's the matter?
2 REPLIES 2
adamhahaEU2VH
820 Views, 2 Replies
This model is imported through FBX.
The automatic smoothing setting of 0 is useless. It shows that the hard edges are really green and hard edges, and it is useless to press "hard" again.(as shown in Figure 2)
It is not a problem with smoothing groups. It is still the case when all smoothing groups are set to 1.
After UVW expansion, it is not a UVW problem.
This problem can be solved after Tessellate, as shown in Figure 3, but the problem is that I want to know why this happens and how to judge such smooth and wrong objects in a large scene through script (of course, I will study the script first)
Original, FBX importedOriginal, FBX importedAlthough the hard edge is displayed and I pressed the "hard" button, it is still wrongAlthough the hard edge is displayed and I pressed the "hard" button, it is still wrongAfter Tessellate, the model is correctAfter Tessellate, the model is correct
2 REPLIES 2
Try to reset normals - Edit Normals modifier, select all and click reset. Imported model from other applications can sometimes have broken or locked normals.
Thank you. It's really a normal problem. Click to flip the normal.
