3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
textures on a loft object
3 REPLIES 3
julie_elsen
426 Views, 3 Replies
julie_elsen
I want to texture an object made with loft but it doesn't work as I expected. Probably a simple mistake in settings but I can't find it. When I make a texture, just a very simple picture from the internet put in bitmap and drag the material on the loft object, I only see a flat brown color. When I use the same material on a box, I get the correct material. I added a quick printscreen. If the issue is more complex than I thought, let me know and I will add a zipfile with the whole 3ds file and pictures.
Tags (2)
3 REPLIES 3
10DSpace
in reply to: julie_elsen
10DSpace
@julie_elsen
You need to provide UVW Mapping for the loft object and there is a check box to "Apply Mapping" in the Surface Parameters Rollout of the Loft which is not checked by default.
Check that box and you should see your bitmap.
@julie_elsen
mromagnoli
mromagnoli
Dear @julie_elsen
Welcome to the community!
I made a similar design and activating Apply Mapping corrects the map in the Loft.
I hope this helps you. 😎
Regards
Arq. Marco Romagnoli
AutoCAD Certified Professional | Revit Certified Professional | 3Ds Max Certified Professional | Fusion Certified User | Autodesk Certified Instructor | VRay Certified Instructor
Dear @julie_elsen
Regards
julie_elsen
julie_elsen
Thank you very much!
Sorry for the late response. I had to put my project a side for a while.
