Hi. I'm new with 3DS max and kind of new in 3D in general, I'm following some online courses to improve my skills but i've run into a problem with a modifier, I'm sure it has a pretty simple explanation but anyway.
When I try the symmetry modifier on an object, for some reason the parts that are affected by the modifier don't match up with the size of the original geometry. In the attachment i made an example. I used the exact same box on both sides and one side is perfectly aligned to it, but the other one seems a lot bigger.
How can I match the sizes so I can have perfect symmetry?
Solved by 10DSpace. Go to Solution.
@Anonymous
Check for nonuniform scaling of the base object before you add the symmetry modifier. To do so, make sure "View" or "World" are selected for the Reference Coordinate System and select the Scale transform tool and then check the values in the x, y and z fields at bottom of max interface. If any are not all positive 100%, you have nonuniform scaling and you need to reset Xform as described in image below:
After resetting Xform anc collapsing as above, try applying the symmetry modifier and see if you get the expected result.
