3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Swift loop acting weird?
12 REPLIES 12
Message 1 of 13
4070 Views, 12 Replies
So I'm using the Swift loop tool, (I'm a beginner) and when I hit shift so that it goes to the middle, it doesn't just create the edge loop? I'm not sure how to explain it. On one axis, it works fine when I use the tool, and use shift to bring it to the middle. But on the other axis it doesn't work. What do I do?
I put a picture showing my problem
12 REPLIES 12
Message 2 of 13
miledrizk
Shift + Swift Loop doesn't just place a loop between existing loops.
It will modify the newly created loop based of the surrounding loops.
Picture 1:  i'm pressing the Shift but before creating the loop
Picture 2: after creating the loop
miledrizk@gmail.com
3DS Max 2021, V-Ray 5.2
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
My YouTube Channel http//www.youtube.com/c/MiledRizk
Message 3 of 13
miledrizk
Now if you're interested of only connecting the edges by their middle
Then use the PConnect tool instead.
Press Shift and click one edge then drag, without releasing the mouse button, to the
Other edge and release the mouse button.
miledrizk@gmail.com
Message 4 of 13
in reply to: miledrizk
I don't really get it. Also, now, when I create my  first edge loop using shift, it doesn't create the edge loop in the middle?
Message 5 of 13
So how do I just create edge loops in the middle, then? I'm lost lol
Message 6 of 13
miledrizk
in my second comment i recommended the PConnect tool,
It's below the swift and i explained how to use it.
Just give it a try.
miledrizk@gmail.com
Message 7 of 13
miledrizk
ah sorry
I'm a bit tired now,
The PConnect will let you create edges one by one,
For a loop it's better to go to edges subobject level, select a whole ring of edges and use the
Connect tool in the Edit Edges rollout.
miledrizk@gmail.com
Message 8 of 13
LOL no worries! Sorry, I don't know any of what you suggested 😕 Where is edge subobject level? But actually that P loop thing helps. I don't really need an edge loop in the middle. But I'd appreciate if you could tell me how? It would come in handy in the future. (I'm following an Udemy course right now, but learning stuff outside of it is good.)
Message 9 of 13
miledrizk
I attached a picture below showing the selection ring and the Connect tool,
Next to the Connect tool there is small button if you click it you'll have the connect settings where
You can choose how many connecting edges you want, and you can play with the spacing between them
And slid them if you like.
If you just click the big connect button you'll apply the last setting you used. By default you'll add only one
Connecting edge.
miledrizk@gmail.com
Message 10 of 13
Swift loop is a very handy tool. The fact no default shortcut allows to place it in the middle of the edges is quite frustrating.
There are a lot of ways to do it but if you are yet interested in using swift tool you could use "center" intermediately after using swift loop.
It is located in the graphite tools ribbon>modelling> loops> open the sub-menu below> loop tools> center.image.png
Yes, quite convoluted location but it opens a window that can be kept open. Also you can assign a shortcut or add a custom button in the graphite ribbon, It is called "Center Loops" in the customisation menu.
Message 11 of 13
So far that's the only thing I miss about blender. (I tried learning blender first but it was so not beginner friendly lol.) I don't really understand, but I'll revisit this in a few days because maybe by then I'll have learned the program well enough to do what you said 🙂
Thanks!
Message 12 of 13
Is there a way to use P connect and make the line thing go in a straight line?
Message 13 of 13
miledrizk
With PConnect you cannot,
Let's say you need a cut between two edges that share the same polygon,
Select that polygon, then in the Edit Geometry rollout, click Slice Plane,
A yellow plane will show up. Now rotate that plane and move it so it's placed where
You like the cut to be, and click the Slice button.
For a straight vertical cut or a horizontal one, you can activate the Snap Angle (CTRL + A) so you can rotate
The slice plane by an increment of 5 degrees.
miledrizk@gmail.com
