3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
sweep modifire to create door trim
2 REPLIES 2
galininatatanaTC34G
437 Views, 2 Replies
hello. help me figure it out. I use the sweep modifier to draw the door trim. The result is an object like in the picture. What am I doing wrong? Or I don't have the 3 ds max 2021 program configured2021-02-10.png
2 REPLIES 2
The size of the profile you are sweeping is much larger than it needs to be, OR your door frame path is much too small.  Check the sizes of the both your profile you are using in the Sweep, and the size of your door frame path, and be sure they are built to the correct size.
Chris Medeck
thanks, I changed the size and everything worked out
