Strange problems with deleting lines
This widget could not be displayed.
Hello :)) I'm importing a file from the 3d rhino in 3ds format and after deleting the line I press Undo or save and having such a malfunction. I working witch "edit poly"  modifier. can you help me, please :)))))
miledrizk
Well there is no malfunction here, this is how Max works,
Just two things you need to worry about:
1- When you're deleting a segment, select the edge then use CTRL + Backspace,
Or use CTRL+Remove command. This way you will not have any leftover vertices.
2- Try, as much as you can, not to have triangles in your objects. Always Quads(4 sided polygons),
Because when you're going to apply the Turbosmooth modifier or the MeshSmooth modifier,
You'll get much better results with Quads than with triangles.
miledrizk@gmail.com
3DS Max 2021, V-Ray 5.2
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
My YouTube Channel http//www.youtube.com/c/MiledRizk
thanks for attention:))))  But I already use this 😕  why after undo does not act redo 0_o?
miledrizk
Since i started using 3ds max with Max 7,
I had this annoying problem of the Undo Redo thing!
Many actions and tools, suddenly, delete the history!
Until now it's not fixed!
If a user is used to AutoCad or another software like Rhino,
This user will expect the same behavior regarding the Undo Redo!
But surpriiiise!! :))
It's so unpredictable and clumsy!
miledrizk@gmail.com
