3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Splines dissappear when using editable poly modifer.
1 REPLY 1
1388 Views, 1 Reply
Just curious why when adding editable poly modifier to the stack for my custom shape why everything disappears. I tried a similar experiment with an ngon and things seemed to work fine with an ngon but not my custom shape.
1 REPLY 1
domo.spaji
Splines must be closed and without intersections in same spline.
If you apply extrude modifier you will see "bad" splines without capping polygons...
