Does anyone know how to turn off snapping of splines when trying to modify the shape using vertex tangent handles? It seems that fine movement is overridden by a snapping action.
Cheers!
Solved by CAMedeck. Go to Solution.
Gentle curves will sometimes snap to a straight line. To disable this, uncheck Optimize in the Options rollout of the base Spline object.
Chris Medeck
Thanks, mate! That worked
