I'm creating some paths with Line tool in Max 2020.
How can I avoid twisting with a sloping, turning spline. It's for a hill model with a road.
Below is an example. I'm not going that extreme with the slopes, but at lower slopes the twisting is still too noticable.
Thor Nielsen
3D GeneralistSolved! Go to Solution.
Thor Nielsen
Solved by thor98_. Go to Solution.
I'm reporting back that my friend suggested I use Sweep modifier.
The modifier does the job. Can turn off banking with it which is apparently the culprit.
Happy modeling everybody 😊
Thor Nielsen
3D GeneralistI'm reporting back that my friend suggested I use Sweep modifier.
Thor Nielsen
3D GeneralistCan't find what you're looking for? Ask the community or share your knowledge.
