3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
Spacing Tool Twist
8 REPLIES 8
Message 1 of 9
mtzvetanov
1134 Views, 8 Replies
Spacing Tool Twist
mtzvetanov
Why is there no twist parameter on the spacing tool?
Or am I missing something?
I have a loft object that I have custom twisted. Now I need to place small square objects along one side of this loft object and these need to, of course, follow the twist.
I can't afford the time to rotate them manually after using the spacing tool to place them along the path.
Is there a solution to this I am missing? I can't be the only one having this issue.
Unfortunately I cannot share the scene (NDA).
What I get...
What I getWhat I get
What I need
What I needWhat I need
Spacing Tool Twist
What I get...
What I need
Labels (1)
8 REPLIES 8
Message 2 of 9
domo.spaji
in reply to: mtzvetanov
domo.spaji
Path deform modifier
Message 3 of 9
mtzvetanov
in reply to: domo.spaji
mtzvetanov
Yes i know. Thank you for the reply. The Path Deformer is great...
...BUT! and it's big but.
The path deformer works only on 1 object right and I have instances. However, it wouldn't be an issue to just attach all objects to 1 and deform IF I could then custom twist the deformer as I can with the loft compound object 😕
And therein lies my problem.
Message 4 of 9
That`s the best i can come up with....
I would just use PathDeform and use the Driven Rotation for the twisting.
It`s totally procedural if you instance Pathdeform, you can change the spline, the twisting. Make sure you build the two objects with the same orientation.
PathDeform copied instead of instanced to the stones->Preserve Form by element, IF you don`t want them to deform. Offset with X-form
Message 5 of 9
mtzvetanov
mtzvetanov
Thanks so much for the idea! I will definitely be trying this on Monday.
Message 6 of 9
mtzvetanov
mtzvetanov
Thank you so much! This is perfect and much quicker than what I've been doing.
The only downside is that I can't have the stones as instances, but this is a very minor downside, as making copies and attaching to 1 object gets done in a matter of seconds.
You have saved me many hours of work time.
Thank you again!
Thank you again!
Message 7 of 9
domo.spaji
domo.spaji
You're thanking yourself and not following  @Anonymous procedure.
But if you don't mind some deformations from your way, you can still keep instancing...
Just attach instanced objects in (pro)boolean compound and you'll have single obj. with "instanced elements".
Than add Path Deform to that (pro)boolean obj.
Message 8 of 9
mtzvetanov
mtzvetanov
I noticed that 🤦🏼‍:male_sign: but I couldn't delete and reply properly.
Thanks, that's a good method. Hadn't thought of it.
However, it's for a product that needs to be as close to the real thing
as possible, so no deformations allowed.
Thanks for all your help and tips. Awesome stuff mate. You're the best.
Message 9 of 9
domo.spaji
domo.spaji
I just noticed "Preserve Form by element" in Aons message. That's new thing from 3rd gen. of Path Deform.
If that's keeping form on "your way" can't see reason for not working on "my".
In that case there's unnecessary steps in @Anonymous procedure.
