Spacing tool for multiple objects?
Is there anything like that? Object paint would work but it only allows 500 instances, I need way more. I have 3 different objects and need to make them follow a spline in a random order with a distance between them
rendermaster
group them then use Spacing Tool
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Just about 3 weeks ago adsk released a new set of cloner MCGs (for 2017) that will do exactly what you are asking. (randomizing objects on a spline.)
To do this, you need to get the new MCGs and install them: (http://www.scriptspot.com/3ds-max/mcg/3ds-max-2017-mcg-samples)
Then:
1.) Create your path
2,) have your random objects ready, and linked to a dummy.
3.) CREATE the PathCloner Object. (Pick the spline)
4.) On the path cloner ADD a "Cloner_Mesher" modifier and hook everything up as shown in the image below.
Hope this helps.
