3ds Max Modeling
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max modeling topics.
size problem
5 REPLIES 5
1893 Views, 5 Replies
size problem
when i import my drawing from autocad to 3ds max drawing becomes huge in 3ds max. walls was 300mm thick but in 3ds max 300 mm looks so small
size problem
5 REPLIES 5
jackietsteh
jackietsteh
Do you check your autocad file unit?
Best regards,
Jackie Teh
Portfolio: http://www.coroflot.com/jackieteh
Youtube Channel:https://www.youtube.com/user/jackieteh
Best regards,
Jackie Teh
in reply to: jackietsteh
its like this and i import like this is it wrongScreenshot_6.pngScreenshot_7.png
Fadhil_Farook
Fadhil_Farook
Try this:
What Units did you setup in 3DS Max. If it's already Millimeters, then after importing the AutoCAD Object, create a Cube that's 300mm and see if it's the same.
If the above suggestion has negative results, then when you import the AutoCAD file, in the import Dialog box, turn off RESCAL that's next to the INCOMING FILE UNITS.
Post any progress or issues please.
Try this:
leeminardi
leeminardi
The "Insertion scale" setting in AutoCAD has no impact on the scale of importing an AutoCAD drawing into 3ds Max.  It is referenced when another file is imported into AutoCAD.
The important parameter for you is the System Unit Scale in 3ds Max (Customize  --> Unit Setup...).  Set that to millimeters and you should be all set.
lee.minardi
lee.minardi
thank you all
thank you all
